Horn relay buzzer goes off without key in ignition
Is this normal operation? If I open the door the buzzer goes off regardless if the key is in the ignition.
For those of you who don't already know, I hate electric problems. :mad
Everytime I cut a wire, I let the smoke out of it. :lol:
Additional Info:
This may be normal, I dont know. The buzzer goes off when the door is open after I move the key to the "on" position. If this is normal, I may disconnect it because that buzzer is quite annoying.
[Modified by Jack71, 8:35 PM 8/14/2003]
Additional Info:
Re: Horn relay buzzer goes off without key in ignition (Jack71)
No No---The key warning buzzer only buzzes when the keys are in the ignition switch and you open the door. I bet that the small switch in the column is broken and is making contact all the time, a very common problum. The tele-tilt switches are $$$ but I believe that the std column switches are common and still avaliable. Thad PS that will bust you on PV
Re: Horn relay buzzer goes off without key in ignition (TNT)
Thanks man...
I just determined after reading this that I'm pooched...
http://forums.corvetteforum.com/zerothread?id=129360
Anyone making these little switches for TT? The cylinder and horn relay/buzzer are both new.
[Modified by Jack71, 8:55 PM 8/14/2003]
