Should I sell my TPI and get a BB?
Cruise-In VII Veteran
St. Jude Donor '07
I like the 454/6 speed combo. Whatcha think? :crazy: I guess I can blow off the paint job another year.
Re: Should I sell my TPI and get a BB? (Budman78)
IMO - The best bang for the buck is the large CI. small blocks. If you remember Monty - which was an extreme case made nearly 700 hp and 600 foot pounds of TQ out of a 427 ci Dart block.
Those 415 - 427 ci small blocks in the milder states that only make 500 hp are making mid 11 second runs. What more could you want?:)
Senior Member since 1492
Re: Should I sell my TPI and get a BB? (Gameshow Bob)
you break your transmission and you want more power??? :D
Get a stroker and LT1 retro intake for your current set up. The tpi while not support big horse numbers like the LT1 intake can. This is the route I am going.
Re: Should I sell my TPI and get a BB? (Fevre)
I thought that an lt1 was reverse flow so you can't use it or something to that effect :crazy:
[Modified by battsup, 9:50 AM 8/15/2003]
Re: Should I sell my TPI and get a BB? (battsup)
You can use the intake with some modifications. A guy sells them premoded for about $400 at www.lt1intake.com I have one on my Formula. Here is a pic of one, notice the dist in the back of the intake, LT1's do not have dist:
[Modified by Fevre, 11:57 AM 8/15/2003]
YES!!! Budman78, if my '82 (Cross-Fire/700R4/2.87:1) wasn't in as-delivered condition (see sig), and there-fore still 'worth-something', there'd be a hopped-up ZZ502 between the fenders now, backed by a THM400 & 4.11 gears. By the time you build a big-cube SBC (415-421-427-454), with a bottom-end capable of making 600 HP without fear of coming home-on-the-hook' (splayed caps, after-market/high-dollar block, billet crank, H/D rods, custom pistons, small-base circle cam, etc.), you'll have MUCH more invested than swapping-over (water-pump, headers, eytc.) to the Rat. You won't need higher compression in the Rat to make what REALLY accelerates your car; TORQUE!!! It'll be less tempermental, too (instead of 'winding-up', it'll 'GRUNT'!), AND you'll have a motor that is 'too-big for NHRA Pro-Stock'!!! How many Corvette owners can say THAT??? :yesnod:
P.S.: as I've stated before, on Easter, I saw a guy with a ZZ502/THM400/'on-sale' converter/3.90-gears/slicks run 12.03 @ 109 MPH, on pump-gas, shifting @ 5300 RPM. I talked to him in the pits following his 2nd run (broke the rear-end on launch!!!), and I believe it was bone-stock, outta the box (crate?). Think you can run THOSE kinda numbers with a streetable SBC?
Re: Should I sell my TPI and get a BB? (vvv90)
If you want a cruiser with that BB sound and gobs of torque. If you want something that you drive often, somewhat economical, and strong go the L98, LT1, LS1 route.
Re: Should I sell my TPI and get a BB? (Glensgages)
Guess if you don't mind going faster, you could try this guys combo:
http://forums.corvetteforum.com/zero...ofile&id=22200
A 383 with modified tpi will produce numbers in the driving range near a BB for less $ and a lot less weight.
Remember that changing to a BB will entail different brackets for all accessories and exhaust manifolds and headers. Due to the extra weight, you will probably end up making changes to your suspension as well.
Re: Should I sell my TPI and get a BB? (Brettmc)
I went with the stroker over the BB for the weight savings and driveability. I get 22 mpg and have run a 13 flat (only been to the strip twice). I know with better tires I'll easily be mid 12's and with nitrous I'll be deep in the 11's. I have jsut over 400 ft. lb. of torque at the rear wheels (only 290 HP at the rears though :(). I'm happy with the setup, but if I had to do it again I'd start with a LS1 block and supercharge it. Probably wouldn't have costs TOO much more. :rolleyes:
