Converting 73 front bumper to earlier 68-69 chromies???
I searched the archives but found limited info.
How much would it cost to convert? Ballpark figures are fine :D
Re: Converting 73 front bumper to earlier 68-69 chromies??? (vvv90)
Depends on how you want to do it. If you just want to patch in some raw fiberglass and some donor pieces cut off a '68-'72 front surround, then bolt up a used bumper and grilles, you're probably talking about $800 to $1k. Then you have to paint it to match, which would end up being a full paint job most likely.
If you want it done "right" then you'd have to replace the top surround, bond in the fenders, buy a front valance panel, and then repaint. New panels plus a new bumper, guards, grilles, brackets, and accessories is probably in the $2500 range.
Either way, you'll be left with a car that is worth less than it was before you started hacking on it. If you want a chrome bumper car, buy one. There are plenty of them out there to be had at fairly reasonable prices. Don't hack up a '73.
Just my $0.02
Just my $0.02
Re: Converting 73 front bumper to earlier 68-69 chromies??? (Wrencher)
Alright alright. I'll leave it alone. BTW: the cars not original anyways, but I should probably leave it stock looking.
I thought about this, too - since I'm putting the 75 nose on the 70 rear clip.
WAY too much work - forget about the price of all the chrome goodies to "make it right". I will be quite happy to have my "72.5" look like a 73.
Spend the $$ on go fast parts - more fun for the buck.
:seeya
:seeya
The only way to do it would be to put a 70-72 front clip on the car. Should be able to pick up the clip for $1000-$1500. Then install and paint costs. Maybe $3000 total??? Better off to trade.
tom...
tom...
