rear shock r/r in TX
installed left side rear shock on the 75 drop top,, KYB's :steering: have to work on the car late in night,, to damn hot in the day time... will finish up tomorrow :cheers: the old shocks were DEAD... :seeya
Re: rear shock r/r in TX (petty44)
Check all your bushings, camber settings and diff fluid level while you're in there.......
Also, check the torque on all bolts - esp the diff cover bolts that hold the rear spring.
