When should my secondaries open
Had the top of the air cleaner off and wanted to see the secondaries open up. Held the throttle open for a couple seconds but neither the butterflies or the top flap budged. I can't even push the butterflies open with a screwdriver, is this normal or might I have something binding. The car is a 78 w/L48 and stock carb. My son said the tach read 4000 rpm before I let off.
Re: When should my secondaries open (Jeff78)
There are folks on here that are much more knowledgable than me, but it is my understanding that they will not open unless the motor is under load. In other words, sitting in the driveway and hitting the gas is not a good indicator.
Take it for a drive and get on it hard and you'll know if they are opening or not...you'll hear them. It's as deeper tone. Don't try to open them by revving the throttle in neutral (or park) you'll hurt something! :thumbs:
Re: When should my secondaries open (hudman)
In addition to only working on demand there is a secondary lock-out on the fast idle cam/linkage that will not allow the seconaries to open while the choke is on. So if the engine is not fully warmed up or the choke is mal-adjusted the secondaries will not open.
Re: When should my secondaries open (bluevetteman)
And to add to the caution on the choak lockout on the Quadrajet, you will not be able to manually open the air valve unless the throttle is wide open (don't try this with the engine running unless you put a basket under the block to catch the grenaded parts).
The secondary air valves will not open as long as there is enough manifold vacuum to hold the vacuum break / choke pulloff in the retracted position. When you open the throttle under load (only), the manifold vacuum drops off and the vacuum break retracts to the same position as when the engine is off, letting the linkage allow the air valves to open as required. The secondary throttle blades will not open if the choke is still active, but you don't want to go there because the power would push you past redline (at least for a couple of seconds!).
Re: When should my secondaries open (Rich's78$pit)
crawl in the engine bay, get the wife to lower the hood down on you, then get her to drive on the freeway and nail it. Note: her head will have to be out the window so she can see. If she is mad at you she will slam on the brakes and you and the hood will go in the ditch. On your way out- tear out as many vacuum line and wiring as you can..... :lolg:
