Leaky power steering heads up.
I just voted (yes) in the powersteering leak poll. I thought I would give you a little warning about overfilling. Especiallty on S/B's.... If you overfill the reservior, the excess will run right onto the lower control arm bushing and make mush out of it very quickly. Once it overflows you cannot wipe it off fast enough. Use a small funnel and add slowly. Lower control arm bushings are not easy to change.
[Modified by bluevetteman, 6:57 AM 8/10/2003]
