Brake Problem...
Brake Problem...
If I drive my '68 after it was sitting for a few hours... My brake pedal goes all the way to the floor... and the car is hardly breaking... After pumping the brake a few times and driving the car.. the brakes operates normally again..
The master cylinder is full and doesn't lose fluid... Could it be that my master cylinder is bad??
[Modified by GrandSportC3, 10:48 AM 8/9/2003]
Re: Brake Problem... (docmow)
i do not know rfor sure but when that happen to me at 75mph i repaced iy
Re: Brake Problem... (GrandSportC3)
Hi
Who needs brakes ? :lol:
Try to bleed them. If you find air in them, well the surge starts.
Are you still operating the middle age lip seal caliper pistons ?
Gunther
Gunther
Re: Brake Problem... (WESCH)
Hi
Gunther
Gunther
I would go through the proper bleeding sequence first. It was pointed out here earlier in the week.
So: left rear, right rear, left front, right front.
BTW, I am changing master cylinders next week, but only because I am becoming a chrome freak! :rolleyes:
Re: Brake Problem... (OHSIXX)
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Is there some reason behind the other sequence?
Olivier,
Sounds like a master cylinder to me. I agree it's easier to replace it.
:seeya Jeff
Re: Brake Problem... (JRD77VET)
I've always been told to start at the farthest from the master cylinder and work towards the closest. RR, LR, RF and LF.
Olivier,
:seeya Jeff
Olivier,
:seeya Jeff
Olivier,
:seeya Jeff
Olivier,
:seeya Jeff
Try this, (pass) PR, DR, PF, DF.
I had a problem where I would get soft pedal, and when re "stabbing" would be firm again. I cahsed this one for a year. I finally determiend it was the master cylinder. Because I wnated to keep my original master, I bought a rebuild kit ($32) and rebuilt it. I followed the instructions in the GM manaul; cleaned all surfaces, reinstalled and bled. My brakes have never felt so good. Hard; no fad or pull, incrediable! :smash: :smash: :smash: :hurray:
Re: Brake Problem... (gliot1)
I'm not concerned about originality... :D :D :D.. so I might just go with a new one...
Cruise-In IX Veteran
I do not know about your calipers, but mine have bleeders on the top and bottom. Both of them need to be bleed to remove any air in the caliper.
Re: Brake Problem... (Sigforty)
I have stainless steel o-ring calipers and they are only 2 years/15000 miles old... I don't think that I have air in the system.... I'm 99% sure that it's the Master Cylinder....
Re: Brake Problem... (boredsoIstrokedit)
Then just replace it already.
Grandsport - it sounds to me like the seals in your master cylinder are going bad. Once you pump 'em a few times they swell a bit and you've got pressure again. That would explain your situation.
I don't disagree with the bleed suggestions, but it sounds like you are pretty sure it's not calipers or air in the lines. That being the case, MC would be the next logical culprit.
:cheers:
:cheers:
Re: Brake Problem... (lyonsh)
:cheers:
:cheers:
