What set Gymkhana suspension apart?
I have seen Gymkhana suspension mentioned as an option on some Corvettes in various places, and I have a quick question for the C-3 owners here....
Without the build sheet on my 1978 L-48 Corvette, how can I tell if I have Gymkhana or standard suspension? Also, was there really that great a difference in the handling? :confused:
Thanks!
Thanks!
Re: What set Gymkhana suspension apart? (Trevelisek)
In a related question: What are the spring rates for this suspension front and back? For an '80 specifically if it varied year to year.
In addition to a rear sway bar, the front sway bar was larger diameter, the rear leaf spring was 7 leaf vs 9 leaf standard, and the front spring rate was 550 #/in. I don't think this varied by year. I don't know offhand what the rear spring rate was.
5$ option.......couldn't have been all that much. Although, bigger, and stronger suspension parts are usually better!
:cheers:
:cheers:
Re: What set Gymkhana suspension apart? (WydGlydJim)
R u serious? it has got to be more than a $5 option because the metal alone for the rear sway bar would be worth that much.
[Modified by battsup, 6:29 PM 8/9/2003]
In 1978, FE7 was a $41 option.
It included a thicker front sway bar(1 1/8"), a rear sway bar(7/16").
550 lb front springs, 292 lb 7-leaf rear spring.
It also included specially valved shocks.
Stock suspension was 300lb / 150 lb or so. 1" front sway and no rear sway bar.
I had my car at a "gymkhana like" setup at one point, with the stock rear leaf and the 550 lb VBP front springs. It was pretty nice. Changing to the 360# fiberglass rear spring did not affect the driving sensation at all. Only a clock really could have told you which setup was "faster". I'm sure the less weight and increased "responsiveness" of the FG spring made it handle better.
In 1980, FE7 cost $55.
-Steve
-Steve
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
Re: What set Gymkhana suspension apart? (Pacin'California)
1974 $7.00
1975 $7.00
1976 $35.00
1977 $38.00
1978 $41.00
1979 $49.00
1980 $55.00
1981 $57.00
1982 $61.00
These prices are listed in the Corvette Black Book
1975 $7.00
1976 $35.00
1977 $38.00
1978 $41.00
1979 $49.00
1980 $55.00
1981 $57.00
1982 $61.00
Re: What set Gymkhana suspension apart? (Gameshow Bob)
FE7 was the most aggressive suspension system ever offered on a Corvette even tho horsepower reached an all time low.
FE7 spring rates (load/deflection) and wheel rates (vertical force at the wheel) increased approximately 70 percent) over the standard suspension. FE7 front springs were rated at 550 lb/in versus 280 lb/in for base while the rear spring rate was rated at 304 lb/in versus 170 lb/in for base. The overall ride rate was increased approximately 66%.
FE7 also included heavy duty shocks and I would like to pick up a set...used or unused.
Pretty stiff huh? But as indicated great for road racing activities are taking hilling curves.
