Vroom, Vroom
Re: Vroom, Vroom (Neo Fender)
We currently have Three left instock at our facility and they are ready for immediate shipment!!! Dont delay as this initial order will not last!! Current production numbers available 001, 010, 015, of 200 produced. (Bid offers are currently being taken on number 001) **Yea thats right #001**
Wonder what the bidding is up to for #001. :confused:
Re: Vroom, Vroom (Boofers)
I didn't see any specs for this engine on that site? Anybody know what its torque/horsepower ratings are? Is it worth the Only $20,454?
510 @ 5,750 RPM
Torque
493 ft./lbs. @ 4250 RPM
Max. Rec. RPM
6,300
Compression Ratio
10.2:1
Block
12370850 Mark VI, 356-T6M Aluminum Alloy, Improved ZL1 Good For 650 HP
Bore
4.250"
Stroke
4.00"
Main Bearings
12329723
Main Caps
Four-Bolt Splayed Steel
Crankshaft
03963523 Forged 1053 Steel 4.00" Stroke, Nitride Treated.
Connecting Rods
10198922 4340 Forged Steel, Magnaflux Inspected And Shotpeened
Connecting Rod Bearing
12329715
Pistons
88961461, Forged Aluminum, Pressed Pin
Piston Rings
12498734, Plasma-Moly
Camshaft
88961447, Mechanical Roler Tappet; Lift: .640” I, .598” E; Duration @ .050: 236° I, 232° E; Center Line - 110 ATDC I, 109 BTDC E
Lifter
88961452, Mechanical Roller Tappet
Timing Chain Kit
12371053, Heavy-Duty Single Roller
Timing Cover
00330850
Flexplate
14001992, 168 Tooth, 14" OD, For Automatic Transmissions
Oil Pan
14103141, 6 Quart
Windage Tray
All New Design, Teflon Coated
Oil Pan Gasket
10159519
Oil Pump
03969870, Heavy-Duty
Balancer
10216339, 8" Harmonic Damper
Cylinder Heads
12363399, Signature Series 356-T6 Aluminum Alloy "Oval Port", 110cc Combustion Chamber
Cylinder Head Stud
25534347
Cylinder Head Gasket
12363414
Valves
12366987 2.25” I, Stainless Steel; 12366988 1.88” E, Stainless Steel
Valve Spring
88961454
Valve Lash
.016 I, .018 E
Rocker Arms
12361323 Extruded Aluminum Alloy, Roller Design, Bow Tie Logo, 1.7:1 Ratio, Stud Size 7/16"
Push Rods
88961450 I, 88961451 E; High Performance One-Piece
Intake Manifold Lower
12464482, Aluminum
Intake Manifold Upper
12464484, Aluminum
Wiring Harness
Included
ECM
Included
Valve Covers
Special, Not Sold Seperately
Water Pump
14058915, Aluminum, Short Style
Distrubutor
01104060 HEI, With Melonized Cam Drive Gear, CPU Controled
Spark Plugs
25164642 R43XLS, Rapid Fire #4
Ignition Timing
Base 10 Degrees
Fuel
93 Octain Unleaded Premium Gasoline
Technical Notes: Melonized distributor gear must be used on all crate engines with steel camshafts.
