Seat Disassembly?
Old 08-08-2003, 11:40 AM
ImBatman
ImBatman's Avatar
Default Seat Disassembly?
Have any of you had problems with the big philips screw that goes through the chrome brace and holds the two halfs together and allowing them to fold forward. I have sprayed anti seize over them and they don't look rusty but man the want come out! :mad Every big screw driver I put on them seems to twist out of the slots instead of turning the screw. Any suggestions please? :confused:
Old 08-08-2003, 11:48 AM
sb69coupe
sb69coupe's Avatar
Default Re: Seat Disassembly? (BlackRat)
Wade, the original seats from my '69 gave me the same trouble. What I did was remove everything down to the bare seat bottom frame and hinge. I sprayed it with PB Blaster, then took a torch and really heated the back side of the seat bottom frame around the screw. It took a couple tries, but it finally broke loose.
Good luck!
Shannon
Old 08-08-2003, 11:54 AM
ImBatman
ImBatman's Avatar
Default Re: Seat Disassembly? (sb69coupe)
Thanks Shannon I will try that this evening. Haven't seen you on the forum lately where ya been? Traveled to Charlotte lately? Coming to the Auto Fair next month at the speedway?
Wade
Old 08-08-2003, 05:43 PM
CF6873
CF6873's Avatar
Another way to break the screws loose it to use an impact driver. I have one that is 3/8" drive and has a set of bits. You wack it with a hammer and there is a twisting mechanism inside that drives the bit either left or right. I don't think they are very expensive and it sure comes in handy. Craig
Old 08-08-2003, 06:04 PM
virtue4u
virtue4u's Avatar
I had lots of problems getting that screw to turn. I did manage to finally get it off with just a lot of grunting.
Old 08-08-2003, 06:08 PM
74 vert
74 vert's Avatar
Location: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Seat Disassembly? (virtue4u)
I wasn't so lucky, I ended up locating rust free frames in Cali.
Old 08-09-2003, 10:52 AM
ManFromEagle
ManFromEagle's Avatar
No one mentioned it here but mine had a locknut on the end of that screw inside the frame.
Sure you took that off first?? :eek:
To Seat Disassembly?
Quick Reply: Seat Disassembly?
