Removing Console
Old 08-07-2003, 08:56 AM
jsybf1
4th Gear
jsybf1's Avatar
Default Removing Console
Hi Forum, I'm a new member although I have been reading the posts for a couple of weeks. Find it very informative. Having trouble removing the the console on my 74, section that parking brake goes through. After removing screws on sides it seems to be attached at rear. Anyone know the trick to removing. Thanks Bob
Old 08-07-2003, 09:03 AM
ORVette
ORVette's Avatar
Default Re: Removing Console (jsybf1)
There is a bolt which you can access under the rear compartment that attaches to the rear of the PB console. I removed the entire rear compartment door assembly when I did mine, don't know if there is an easier way.
Old 08-07-2003, 09:05 AM
Petes73
Petes73's Avatar
There is a bolt that holds the back down. It is under the glove box. You may be able to get at it from the jack compartmrnt, but I always pull the covers and take out the glove box.
To Removing Console
Quick Reply: Removing Console
