GM Performance Crate engine swap
I have been kicking around the idea of a GM Performance Crate Engine.. The 330HP 350 looks like a god fit for my style of driving..<cruising, occaisional rice burn> I would move over the Qjet, but what type of choices of intake is best for this engine. It says it has vortec heads that need a 4 bolt manifold, not 6 bolt??? Anyone have this setup? 71 vert
GM PART # 12486041
CATEGORY: Eng Asm-(must provide commercial shipping address)
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $3,096.80
OUR PRICE: $2,199.00
DESCRIPTION: ENG-330HP
Our lowest priced crate engine, the 330 horsepower 350 HO doesn't sacrifice power or durability, it just pumps up the value. With its four bolt main block, nodular iron crankshaft, powerded metal steel connecting rods and light but strong cast aluminum pistons, this engine screams durability. Add to the strong foundation a pair of 64cc Vortec cast iron cylinder heads and a dual pattern camshaft with just a bit of a "lumpy" idle, and you've got the muscle car small block that you've been looking for. Dressed to impress with chrome valve covers and timing cover, this engine will look great between the fenders of your favorite street rod, muscle car or grass roots racer. The cylinder heads on this great little performer use 1.94" intake and 1.50" exhaust valves that are sprung with 5.7 Liter L31 valve springs. The 64cc chambers yield a healthy, but streetable 9.1 to 1 compression ratio. The cam is a modern dual pattern interpretation of the old '65 to '67 Corvette 327 cam. But with more lift and duration on the exhaust side, it does a better job of clearing exhaust from the combustion chamber. We also decreased duration and lift ever so slightly on the intake side to build more cylinder pressure. The result is a cam that makes great torque and horsepower with the 350 HO's compression ratio. Add the new dual plane intake manifold P/N 12496820, 650 cfm carburetor, HEI distributor, torsional damper, water pump and exhaust manifolds or headers and you've got an outstanding muscle motor with a broad, smooth torque curve and an honest 330 horsepower. This manifold has four bolts, not six, to attach it to the cylinder head. Older six-bolt manifolds will not fit the new Vortec heads. The 350 HO is not intended for marine use, and should only be used in 1975 and earlier pre-emissions street vehicles or any year off road vehicles.
Technical Notes: Engine ID code is CC. Requires a counterweighted flywheel or flexplate, 10105832, 14088646, 14088650, 14088765, or 12554824. Requires torsional damper 6272221 (6.75") or 12555879 (8"). Oil dipstick located on right side. A 650 cfm carburetor recommended. Chrome valve covers and timing cover included. Intake manifold, distributor, flywheel, torsional damper, water pump, and exhaust manifolds are not included. Distributor P/N 1104067 or melonized distributor gear P/N 10456413 must be used on all crate engines with steel camshafts.
GM PART # 12486041
GM LIST: $3,096.80
Re: GM Performance Crate engine swap (OldSchool)
That's a good motor. You have to use a vortec intake, and since the vortec heads origially came on fuel injected trucks, your choices are limited. I think the easiest intake to use is the eldebrock performer vortec. not the rpm or air gap. that will give the best hood clearance. gm also makes a vortec manifold, but I don't know how high it is. Joe
