Carb question for Lars or anyone else who would know....
Would a Q-Jet off of a 1974 L82 4 speed have a Pump discharge ball and discharge ball retainer? I am going by a 4MV diagram and don't seem to remember having this on mine, the rebuild kit came with a replacement pump discharge ball though and I don't really want to have to take the whole carb apart just to find out that mine doesn't have this.
Thanks again in advance.
:thumbs:
:thumbs:
Re: Carb question for Lars or anyone else who would know.... (TotallySmoked)
Yes it will have the ball under the screw-in retainer, but if it isn't broke, don't fix it! You can change the ball after just taking the air horn off.
Re: Carb question for Lars or anyone else who would know.... (Rich's78$pit)
Rich
Thanks, the problem is, I have one screw left over and I believe it is the pump discharge ball retainer. But if it's just a matter of taking off the air horn, piece o cake.
The pump ball retainer screw (brass) has a threaded section at the top and a rod shaped section extending down from that. I doubt the rebuild kit contains a replacement screw because there is really nothing to go wrong with it. The kit includes a new steel pump ball because they can rust if you get water in there but rusting is unlikely unless the carb has sat idle quite a while (the pump action pushes any separated water out with the pump shot).
