Distributor hose connection to carb
Anyone know which fitting the distributor goes into in the carb when you don't have an EGR valve or AIR? Once I know this I can just block off the fittings I won't need. This is for a 1974 Q-jet 4 speed 388 engine.
THanks in advance.
[Modified by TotallySmoked, 2:08 PM 8/6/2003]
THanks in advance.
Re: Distributor hose connection to carb (TotallySmoked)
Take a look at this thread: http://forums.corvetteforum.com/zerothread?id=619544
