Edelbrock intake/holley carb
Old 08-05-2003, 08:42 PM
mikes1973rdstr
mikes1973rdstr's Avatar
Default Edelbrock intake/holley carb
I am wanting to use my stock 73 air cleaner, but use an Edelbrock intake with Holley carb. Question -- Will the stock air cleaner fit the Holley and will the stock hood clear the stock air cleaner???
Old 08-05-2003, 09:05 PM
77Dream
77Dream's Avatar
Default Re: Edelbrock intake/holley carb (mikes1973rdstr)
Well I don't know for sure if the stock air cleaner will fit the Holley but If you need an adapter plate between the intake and carb you might run into hood clearance problems. You could fix that by getting an aftermarket air cleaner with drop base and/or a lower profile air filter.
:cheers:
Old 08-05-2003, 09:06 PM
77Dream
77Dream's Avatar
Oh... and welcome to the forum. :seeya
Old 08-06-2003, 03:26 AM
BB73Chris
BB73Chris's Avatar
Well, on my 73, I couldn't get the stock air cleaner over the 4165 because the filter and floatbowls were trying to occupy the same space.
Old 08-06-2003, 07:13 AM
pws69
pws69's Avatar
I have an Edelbrock intake Holley 650 DP, ,and a stock (black base chrome top) air cleaner on my 69. 350, stock hood, no spacers, no adapters, and NO problems.
[Modified by pws69, 7:15 AM 8/6/2003]
Old 08-06-2003, 07:58 AM
mikes1973rdstr
Default Re: Edelbrock intake/holley carb (77Dream)
Thanks
Old 08-06-2003, 08:00 AM
mountainmotor
mountainmotor's Avatar
Welcome to the forum.
The 73 cowl induction a/f base will not allow the use of the center pivot Holley's w/o basically hammering the base for clearance . The spreadbore type Holly's with their side hung floats will .I don't know about the electic choke models, never used one.
You will though have enough clearance to shut the hood with a Performer manifold and your stock air cleaner .
Old 08-06-2003, 01:10 PM
redwingvette
Support Corvetteforum!
redwingvette's Avatar
Default Re: Edelbrock intake/holley carb (mountainmotor)
I am using the Holley spreadbore #4175 but I had to make a riser for it to work. It hits on thge Vacuum secondary module. Still have a little clearence but not much.
To Edelbrock intake/holley carb
Quick Reply: Edelbrock intake/holley carb
