Installed Trans Temp Gauge -- What do you think?
Well, I installed the trans temperature gauge in the drivers side vent. There are some advantages to having a "driver" ! The other alternative was to replace the clock in the center console. I decided on the vent since the AC is in a milk crate and, well, interior heat is not problem...
[Modified by Jack71, 8:35 PM 8/5/2003]
St. Jude Contributor
Re: Installed Trans Temp Gauge -- What do you think? (Jack71)
Interesting place to put it. Almost looks like a perfect fit. Assuming you pulled out the rotating vent and then installed it?
Re: Installed Trans Temp Gauge -- What do you think? (bgrice)
Nice job. I think if you put it in the cluster, it would have clashed with the factory gauges. :cool:
Nicely done :yesnod: What sort of temperatures are you reading when
1: town driving?
2: Highway cruising?
:cheers:
1: town driving?
:cheers:
I've been trying to get my gauge hooked up for a month now,and finally gave up.What temps do you run?Also are you running the cooler through the radiator,or direct to a transmission cooler?
Re: Installed Trans Temp Gauge -- What do you think? (Avette4me)
Well, I just finished bolting in my steering column today. I don't have any readings yet but I'll post some over this weekend.
Currently, I using the cooler in the stock radiator. I'm going to buy an alum radiator from Tom DeWitt at Carlisle. Going with the dual electric fans too. I wanted to get this gauge installed now to get some "before" readings.
The 400 engine is coming along nicely so I'm hoping to get everything in this fall.
