Forgot to fill torque converter...
Old 08-05-2003, 04:12 PM
dath
dath's Avatar
Default Forgot to fill torque converter...
Erm, I think I kinda forgot to fill my torque converter with a quart or so of fluid before I slapped the engine in... What are my options? Can I just fill the transmission with fluid and assume the converter will be okay? This is a new converter by the way, so I don't really want ot risk it, but I also don't really want to pull the engine back out either. CRAP :banghead:
Old 08-05-2003, 04:28 PM
Larry B.
Larry B.'s Avatar
Default Re: Forgot to fill torque converter... (dath)
No problem at all. Just fill the trans. Start the engine and keep adding fluid until it is just above the add mark. Then Cycle the selector a few times and re check the fluid level You may need to do this a few times. Don't drive the car until the fluid level remains at the full mark.
Old 08-05-2003, 04:29 PM
Wrencher
Wrencher's Avatar
Not a problem. Dump in about 4 quarts, fire it up for a few seconds (so the pump can fill the converter), add 2-3 more and run it through the gears. top it off and your set. You can't hurt it.
Hans
Dooh! Bluevetteman beat me to it...
[Modified by Wrencher, 1:30 PM 8/5/2003]
Old 08-05-2003, 04:33 PM
gkull
gkull's Avatar
Received 1,331 Likes on 1,059 Posts
I've done the same thing also. the problem is air bubbles and your TQ untill it's full of bubble free oil. It will slip to a higher rpm at first. I just fired the motor and let it idle till it got up to temp and then I shut it down for an hour or so and did it again. While it was hot I filled to the correct level before I ever drove it.
just drive it easy at first and get it all filled.
Old 08-05-2003, 04:38 PM
Alwyn678
Alwyn678's Avatar
Default Re: Forgot to fill torque converter... (gkull)
Should not be any problem at all
Old 08-05-2003, 04:40 PM
dath
dath's Avatar
Thanks everyone, I was really worried that I may have to go pulling things back out again. This is a new engine that hasn't been fired up yet, so I just want to make sure that everything is in good working order before I go for it. Just concerend about screwing things up for now, I don't need to drive it (and cannot until I put calipers on it), so I'll just add the fluid and not worry much about it until I get ready drive it:D
Old 08-05-2003, 04:49 PM
Stewart's74
Stewart's74's Avatar
Been there done that :rolleyes:
To Forgot to fill torque converter...
Quick Reply: Forgot to fill torque converter...
