Relocation of Emergency brake brackets on T-arms
I’m still messing with this………
Those of you that have made this change (moved brackets to the top of the arms, for additional tire/wheel clearance); did you still route the shielded cable around the outside of the trailing arm?, or along the inside adjacent the flexible brake line?
I have the brackets off, and am not sure of at what angle to re-weld them (to direct cable inside or outside arm).
Thanks - Mike
