Found where my oil is leaking, but what is THAT part??
So my cousin and I were changing the oil, when he says "Why is there oil comming from this thing?". I need to know what this thing is. I think its the oil pressure sending unit, but as I know nothing about cars, I don't know. This part is located just below the oil filter, which is the green thing at the top of the image. If you look you can see that oil is leaking from where the plug goes into the unit.
[Modified by Dwayne 76, 9:50 PM 8/4/2003]
Re: Found where my oil is leaking, but what is THAT part?? (Dwayne 76)
Yes that is your electric oil pressure sending unit, it needs to be replaced.
:cheers: Larry
:cheers: Larry
Steve :steering:
[Modified by stpman, 9:56 PM 8/4/2003]
Re: Found where my oil is leaking, but what is THAT part?? (69vette66)
69vette66, and STPMan, thanks for the rather quick response! Is this something can be changed by someone with no expierence, or is this garage work??
St. Jude Contributor
That is the oil pressure sending unit, but it's hard to tell that oil is coming from there. Clean it off good... run the car a few times and see if it reappears. If you are ready to change oil it's nothing to get a new sending unit and replace it. And use the white thread sealing tape on all the NPT threads. It's possible that the connection going into the block might break loose first.
(Edit)Changed information about the NPT threads.
[Modified by bgrice, 9:04 PM 8/4/2003]
Re: Found where my oil is leaking, but what is THAT part?? (bgrice)
I cleaned it off a few times, and the oil kept comming out. If you look you will see a small bead of oil forming where the black wire connects to the silver unit. Also, my oil press. needle does a lot of bouncing and always registers over 60 on the oil pressure guage. Could this be a result of a leaking sending unit as well? Oh, also do I need to use a tool to losen that off, or is it just a matter of getting a good grip on it?
[Modified by Dwayne 76, 10:09 PM 8/4/2003]
It is most likely a 3/8 or 1/2 wrench. it should be rather tight. do not overtighten it and when you use the white teflen tape be sure to keep it a couple of threads back from the edge, you don't want any to break off and plug you motor up. Yes it is simple to change. You can do it.
:cheers: Larry
:cheers: Larry
If the oil is coming out where the wire connects--the unit is deffective and needs replacing. If its coming out around the threads(make sure its not leaking down side) put appropriate sealer on threads and re-install after cleaning--cheap item--replace it!
Thanks again 69vatte66, Sixty9 I was hopeing that was an easy fix. :cheers:
