Keisler 6 Speed pics - really :-)
Former Vendor
Here they is.
1979 Vette automatic to 6 speed using our full conversion kit.
Please see our new website http://www.keislerauto.com
[Modified by Robert D. Carguy, 2:34 PM 8/4/2003]
Re: Keisler 6 Speed pics - really :-) (Robert D. Carguy)
Damn, thats sweet....I wish I wouldve known about this. I just got done putting in a 700r4 because I didnt want to tackle all of the custom modification it previously took to put a 6 speed in just yet. How much did it end up costing you? Damnit, now IM mad, I wish I wouldve known. :banghead:
Re: Keisler 6 Speed pics - really :-) (joshs78sleeper)
Actually I see now you say "our" conversion kit....so how much would it cost *me* is the question, lol
Re: Keisler 6 Speed pics - really :-) (vettery)
There ain't nothin on this site (http://www.keislerauto.com/) bout no 6-speed in no Corvette.
Canadian Events Coordinator
Re: Keisler 6 Speed pics - really :-) (Blankman)
http://www.keislerauto.com/gm/transm...ette_68-82.asp
I found it!!! :party:
:chevy :chevy :chevy :chevy :chevy :chevy
Re: Keisler 6 Speed pics - really :-) (Alwyn678)
Alwyn... :nono: Theres no reason to be rude! I was just joking with ya for the stupid comment. :jester But the newbie thing is :bs
I dont want to have to :smash: you up...so lets :cheers:
75Rag's priority shopping list before this post:
1)Finish engine build up, install.
2)Headers, pipes.
3)New vert top
4)Rear suspension goodies
5) front steering / suspension goodies
75Rag's priority shopping list after this post:
2)Headers, pipes.
3)6 SPEED !!!
3)New vert top
:thumbs:
2)Headers, pipes.
3)New vert top
2)Headers, pipes.
3)6 SPEED !!!
3)New vert top
:thumbs:
Former Vendor
6 speed details
We're having a meetinf with our website guru next. I'll make sure we get some good 6 speed stuff up there.
Here's the scoop on our 6-speed conversion kit for the C3.
4-speed manual to 6-speed conversion kit includes:
VIPER T-56 MODIFIED FOR CORRECT SHIFTER LOCATION
ACCEPTS MECHANICAL LINKAGE
USES YOUR BELLHOUSING
RATED AT 650HP
RATIOS: 1st 2.66 (2.52 for Muncie), 2nd 1.78, 3rd 1.3, 4th 1
5th .74, 6th .50
CORRECT LOOK SHIFTER HANDLE
CORRECT STYLE BALL FOR YOUR CAR
LOWER BOOT & TRIM RING
NEW DRIVESHAFT
CROSSMEMBER ISOLATOR MOUNT
ISOLATOR
HARDWARE KIT
KIT FOR MECH OR ELECTRONIC SPEEDO, INCLUDING CABLE
REVERSE LAMP HARNESS
REVERSE LOCK HARNESS
PILOT BEARING (NEEDLE ROLLER)
INSTRUCTION MANUAL
TEMPLATE FOR TUNNEL PREPARATION
LASER CUT PANEL FOR TUNNEL MODIFICATION
NEW PIECES FOR CROSSMEMBER MODIFICATION
PRICE $4195 – THIS IS ONLY $800 MORE THAN OUR 650HP 5 SPEED CONVERSION!
The cross member requires modification which is detailed in the instructions. A 6"x2" slit needs to be made in the tunnel. The laser cut steel panel included in the kit covers the modified area.
A COMPLETE AUTOMATIC TO 6 SPEED CONVERSION KIT INCLUDING ALL THE ABOVE PARTS PLUS:
RECONDITIONED PEDAL CLUSTER AND PEDALS
BILLET STEEL FLYWHEEL AND BOLTS
McLEOD DIAPHRAM PRESSURE PLATE AND BOLTS
McLEOD PREMIUM STREET & STRIP RATED 11" DISC
ALIGNMENT TOOL
LEATHER UPPER SHIFT BOOT
LOWER SHIFT BOOT AND TRIM RING
RECONDITIONED BELLHOUSING AND BOLTS
NEW Z BAR AND CLUTCH LINKAGE
COSTS $800 MORE
The cross member requires modification which is detailed in the instructions. A 6"x2" slit needs to be made in the tunnel for clearance along with an opening for the shifter handle. The laser cut steel panel included in the kit covers the modified area.
RATED AT 650HP
5th .74, 6th .50
NEW DRIVESHAFT
ISOLATOR
HARDWARE KIT
INSTRUCTION MANUAL
ALIGNMENT TOOL
COSTS $800 MORE
If my 383 has a wide torque curve, why would I select a 6 speed over a 5 speed if the 1st and final gears are approx the same?
Re: Keisler 6 Speed pics - really :-) (flynhi)
But the final gear is NOT the same. Really, the 6-speed just gives another OD gear.
IMHO, the 6 speed (T56) is better for 4.10 or deeper gears due to the .5 OD and 2.66 1'st. The 5 speed (Tremec) is better for 3.36 or so gears due to the .68 OD and 3.27 1'st.
