Location of 1980 Oil pressure sensor ???
Re: Location of 1980 Oil pressure sensor ??? (azswede1960)
You'll find it at the rear of the intake near the distributor. It's a cylinder with an electric connector at one end and a 90 degrees oil fitting at the other end.
Stephan
Stephan
Re: Location of 1980 Oil pressure sensor ??? (American Boy)
Sweet ! Found it re-plugged in the connector and lo and behold....we got GAUGE!!! Thanks
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Is the sensor located in the same location a say, a '76? My needle does a lot of bouncing.
