Transmission Coolant Lines !@#$
I bought steel line to run the tranny coolant lines and it's a pain. The line that connects to the upper portion of the radiator is really close to the upper a frame so it won't fit. I tried to bend the line as sharp as I could without kinking it but it won't go. Is there a special 90 degree fitting I can buy or something?
Thanks!
Jerry
Thanks!
Jerry
Re: Transmission Coolant Lines !@#$ (jerryjfunk)
A right-size set of tubing benders should help you out. What ya do is bend it 1st, and then cut it to the right length..........somebody else did it that way and you should be able to too.......GOOD LUCK!
