1980-81's with 700R4 transmissions .....
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Bow Tie Overdrives FINALLY has a crossmember for the '80-'81's for the 700R4. This crossmember will also let you do true dual exhaust without having to swap in an earlier year crossmember that won't just bolt right in.
Check it out here - http://www.700r4.com/catalog/catalog...php?ITEMID=265 --- $180.00
Re: 1980-81's with 700R4 transmissions ..... (BSeery)
82 came with a 700R4, that is why i don't understand why the drive shaft wont fit an earlier c3 without having to cut ours...is the tranny or rearend in a different spot?
:confused:
[Modified by 79corvetteTPI, 2:36 PM 8/1/2003]
:confused:
CI 6-7-8 Veteran
Re: 1980-81's with 700R4 transmissions ..... (C3 Shark Tank)
I've had the crossmember for quite some time now in my 81, probably 2 years I think.
I will switch to the new BTO crossmember the next time I have to drop the crossmember. I don't like how the 1979 version does not bolt up with all 6 bolts.
CI 6-7-8 Veteran
Re: 1980-81's with 700R4 transmissions ..... (Skyhigh)
What type of transmission came on an 82. Will the same corssmember work on an 82?
I got one of the first ones they made I believe, I had the 700r4 installed on 4-24-2001, just dug out the receipt. http://www.c3sharktank.com/tech2/tranny/tranny1.html
