Question for DavidOrr
Hey DavidOrr,
I was reading some archives in this site and came across a post you replyed to that matched my problem EXACTLY.
This is the post: http://forums.corvetteforum.com/zero...585#1544347585
Anyway my question is clarification actually. Yesterday i was putting mine together, for the passenger side, and noticed that of the only two mostly correct positions; One is very tight in the up position and the other wont even hold up the window in the up position....so, for sure your saying that the second more loose option is absolutely the way to go?
Thanks for the assistance.
Re: Question for DavidOrr (jonjollyf4)
UPDATE
Dave i found that your advice didn't apply in my case.
You where correct about there being only 2 possibilities however, i used the position with the most tension strength and it works like a charm...
Thanks for the advice,
