These pulleys are drive my crazy..help
Drivers,
I trying to hookup the so called "stock" power steering pump on my 74 SB. Once I got it in place I noticed the pulley stuck out about an inch and a half past the crank pulley. :skep: After looking at the water pump pulley I noticed it was off too, about a half inch past the crank. I also noticed it has places for 2 belts should there be 3 (PS AC ALT )
So does it sound like the water pump pully is not correct or what ?
Thanks everyone
PS notice I did not use the word Problem or issue :D
Thanks everyone
Re: These pulleys are drive my crazy..help (redvettefreek)
I looked at mine and it looks like the third groove on the crank shaft for the PS pump is an add-on that bolts to the existing 2 groove pully. If you get that part it will stick out that extra inch and half that you need.
If you didnt understand that then let me know, I will shoot some pics for ya.
:cheers:
:cheers:
