What is a L82 or, L8?
Cruising to work, saw a kid about my age with an early 70s C3. The paint was rather rough, but he prob. was going to work on that later...
My question: the thing had a L82 -- or maybe a L88 decal on the hood. What motor is this? It had stock exhaust, but when he got on it, WOW was it good sounding. Did not sound like a low hp v8, but rather a wet and ready sleeper. Maybe he did some work??? I dunno. Just curious.
Thanks.
[Modified by Robey5, 4:35 PM 7/30/2003]
Thanks.
Re: What is a L82 or, L8? (Robey5)
L-82 was the emission years version of an optional high performance engine starting in 73 (rubber bumper in front, chrome in back) The L-82 badges on the hood started in 75. They were, in stock form a pretty docile engine. The L-88"s were available in 67(C2) and 68-69 only. They are quite rare and pruduced over 500 HP. These are not street driven cars and require 104 octane fuel, have no fan shrouds, radio's, heaters or defrosters. I doubt you saw an L-88. Most likely an L-82.
[Modified by bluevetteman, 5:45 PM 7/30/2003]
An L-88 does not have a docile idle.
An L-82 has a fairly docile idle, but it does have a bit of a mechanical lope! Very high duration for a street motor. Surprising that it passes smog. :)
Probably an L-82...
-Steve
Probably an L-82...
-Steve
So,
Then the L82 - is a high hp 350? or...???
Horsepower ratings varied from year to year as Chevrolet attempted to meet changing emissions and fuel economy requirements. L-82 horsepower ratings ranged from a high of 250 in 1973-1974 to a low of 205 in 1975. In 1980, its last year of production, the L-82 was rated at 230 horsepower.
[Modified by Neo Fender, 9:09 AM 7/31/2003]
One additional comment for the L82. When it was introduced in '73 it was only down 5 hp from the LT1 of 72 :D The magazine test of the day put their performance dead even. I like to think of the L82 as a lower compression version of the famed L46 (350ci/350hp). In fact they both used the same cam which has a very nice lope to it.
Except for the very early 70's, the L82 was the high performance engine of the 70's.
tom...
tom...
Re: What is a L82 or, L8? (wcsinx)
I like my L82. :D And they have a decent bite once you desmog these puppies!
Re: What is a L82 or, L8? (bowtied)
Yup. The L-82 is a sweet engine. It's not a ZZ4, but it does OK fine for me!
BTW: There are many C3's running around with L82 badges that don't have an L82 engine. When buying a Vette, check the engine VIN code to be sure.
This is a late L-82 engine. (Flint, Michigan not Mexico. Sorry Dwayne, I could not resist!)
[Modified by paul67, 3:34 PM 8/5/2003]
Re: What is a L82 or, L8? (paul67)
The L-82 is a 350 correct? What would it take to turn say, an L-48 into an L-82? My L-48 has had a mild build up, and is now a 355 Cid. Is that comparable to the output of an L-82, or is this Apples and oranges?? The L-48 is two bolt main and the L-82 is a four bolt main, right? But since niether engine can produce enough HP to sheer the bolts off I think that would be negligable. So, other then that one is a two bolt the other is a 4 can an L-48 match the ouput of the L-82?
[Modified by Dwayne 76, 1:40 PM 8/5/2003]
Re: What is a L82 or, L8? (Dwayne 76)
tom...
Re: What is a L82 or, L8? (Tom73)
Tom, my engine was rebuilt like I said. It has, I beleive flat head pistons, a better cam, not sure which one, but it isn't stock as per Superfast80. I don't know if my L-48 is really an L-48 anymore, and more of an L-82 or L-46
Apples-and-oranges. An overbore of 0.030" to get 355cid is just a minor bore clean-up. Five cid on 350 is a 1.4% increase in displacement.
I was speaking simply of displacement. A 0.030" overbore simply means that 50% of the life of the block is gone as the max is 0.060".
[Modified by paul67, 3:40 PM 8/5/2003]
...Actually I have a 0.40 overbore. And no, that dosn't mean you've lost 50% of the life of the motor, or more with a 0.40. You could say it lost some years, but not as many as 50% :rolleyes: I was wondering though, with .040 bore, and the flat head pistons, and the more aggresive cam, if my car is closer to an L-82, or an L-46 (what is an L-46, anyone have numbers on that Puppy?).
