Rear Coil-over shocks -
I was looking at the rear suspension on my '69 vert..... and I held up an old set of Koni coil-overs to my shocks, and it looks to me like I could just bolt them right on, and get rid of the mono spring... anyone ever tried this, or seen it? I've ran the Koni coil-overs on a few Prostreeters, and they work great! I can't seen any reason why they wouldn't work here...unless the original mono spring adds some geometry function..... ANyone want to add their two cents?
:grouphug:
:grouphug:
Re: Rear Coil-over shocks - (69Rat)
You can use koni coil overs but not on the rear shock mount, that is by far not strong enough. The way to do it is something like this:
What kind of shocks do you have? 8112 or 8212?? If they are SPA1 specced shocks I wouldn't use them on the street (valved for drag racing) because they will get very hot then and may possibly fail.
Re: Rear Coil-over shocks - (Twin_Turbo)
Where did you find the trailing arms?
I have a set of 8212's I used to run on a ProStreet '70 Opel GT, w/a Blown SBC, 9" ford rear, and wheelie bars. I loved the Koni's for being able to adjust them for softer ride, or bump them for the track as needed. I never had a problem with them heating up on me. I'd have to get new springs for a stiffer rate I'm sure. My Opel was only about 2800 lbs.
I figured it's a better rear suspension then the mono setup.
Nahh.. I think these 8212's will end up on my Vette in the near future. I loved the way they worked with my Opel... My real problem right now is the urge to tub my '69 vert... I'd feel guilty about cutting her up, but I love the prostreet look, and functionality. My little '70 Opel GT looked like a 1/2 size C3 anyway! :steering: :hurray:
Here is two ideas I had in mind....
if semi stock form.....
if ProStreet form....
decisions...decisions.... :reddevil
[Modified by 69Rat, 10:04 AM 7/30/2003]
Dang, I want those 8212s too. Problem is, Koni is a Dutch make but they refuse to sell the 82, 81 and 21 series coil overs here. Dunno why, they only sell in North America. I'm desperately looking for a set of 8212 tp put on my car :(
69 Rat. What am I looking at. Are both of these your cars or just pictures you are practicing with? You can't just show pictures like this and not explain. :) :)
Re: Rear Coil-over shocks - (norvalwilhelm)
norvalwilhelm -
These are pics of what I might do to my '69 vert. My issue is that in order to get the stance I want.. I would lose the functioning soft top. I could always get a hardtop and just remove it for topless riding, but it's a bit of a pain. :skep:
I'm deffinately leaning towards tubbing the car.. though I do feel a little guilt, since mine is in great shape, and mostly original BB vert. But can you really argue with the looks of either Pro streeter above?? :thumbs:
