rotor/distributer problems...? please help
okay, lately I've been having a few different problems with my car...after playing with a few things and replacing some stuff I think i have it narrowed down. I'm no mechanic though, so let me explain things and see what you all think.
I seem to bad having problems every morning, or rather, the first time I goto start the car each day. Sometimes it won't start at all, or else it'll start but the RPM bounces around and it'll bounce too low and the car will die. The same thing would happen while driving (if it started). I think I've figured out what's causing it, but I don't know how to fix it. There seems to be getting built up mousture on the contact on the top of the rotor. Just the slightest bit of mousture seems to be screwing things up. When the take a distributer cap off, and clean/dry the rotor contact, the car starts/runs pretty much fine until the next time it gets mousture build-up. I've replaced the disitributer cap, but that didn't seem to do anything. What else should I do?
Just another Corvette guy
Re: rotor/distributer problems...? please help (LAvetteman)
Hey Kevin,
Where is the moisture coming from in the first place? Did you recently have the engine pressure washed? If not you shouldn't be getting ANY condensation in there. Try removing the cap and blowing inside the cap and distributor with compressed air until you're sure it's bone dry in there. Then retry.
Good luck, Greg
Good luck, Greg
Replace the rotor.
Hey Kevin,
Good luck, Greg
Good luck, Greg
Would mousture build-up on the rotor be enough to cause the problems mentioned? Or am I totally off-base?
Re: rotor/distributer problems...? please help (SicChild)
No you're not off base Kevin. Moisture in there will cause a "no start" situation. I've seen the same thing down here in the heat, that's why I asked about the engine shampoo. Weve done many of them and found after the car is started the moisture will draw up into the cap. If it's wiped away it's OK for a while until it draws more from the lower part of the distributor. This will happen over and over until it's actually blown out with high compressed air. If yours hasn't been washed lately and you're not driving through HUGE puddles or with no hood in a rain storm, it's very strange that you'd get moisture re-occuring in your distributor. But each time you remove the cap there's a bit of wetness on the rotor? And each time you dry it the car starts right up?
Re: rotor/distributer problems...? please help (Greg)
Why dont you just spray your distributor with an inhibitor like WD40? That draws the moisture out and works to prevent moisture getting in. :cheers:
Re: rotor/distributer problems...? please help (Graemeinvette)
Sure it is water? It is possible to wick oil spray up the shaft if the bushings are worn out. Check what the moisture is next time it happens - it it does.
Re: rotor/distributer problems...? please help (bigvette1)
Well it looks like water to me...it's clear, same viscosity, etc...I'll try the air compressor thing and also WD40...thanks for all the help guys..I'll keep you updated.
I have this same problem with my El Camino. In the morning sometimes I get no spark. Engine has not been washed in months. Replaced the cap and rotor and still no luck. To get mine going all I have to do is wiggle the cap left to right a few times and then it starts on the first try. Checked all the connections and they are good. I think I will try the wd40 or grease. :mad :rolleyes: :banghead:
Re: rotor/distributer problems...? please help (Robert8096)
Well, I just replaced my coil and it everything seems to be good now. It fired right up. We checked the spark, and it was poor, so I replaced the coil and now it's all good. I'm hoping that was the problem all along. I'll keep you guys updated.
