Dyno #s for new BBC combo
Old 07-28-2003, 03:42 PM
WA 2 FST
Support Corvetteforum!
WA 2 FST's Avatar
Default Dyno #s for new BBC combo
For those who might have missed the recent posts on my new BBC combo, here's what I have:
454ci, GM crate motor
~9.5:1 CR
AFR 305 heads (CNC chambers, as-cast ports)
Edelbrock RPM AirGap intake
Comp Cams hydraulic roller cam (230/230, .578/.578, 110 LSA)
Holley 950 HP carb
Hooker 2 1/8" sidemount headers, JCL baffles
Richmond 5-speed trans
434rwhp @ 5600rpm
450rwtq @ 4400rpm
Call it luck for a first-time BB build up, but I nailed the combo. Yes, most of you hardcore hot-rodders are going to say I need more cam, and if I was going for max power and a higher rev-range I would completely agree. Slap a solid roller in the 244-248 range and it would probably make peak HP at ~6500+ and it would be in the 470rwhp range. But that was not the intent of this exercise. :)
The TQ curve is flat, and HP doesn't drop off much at all. 5600rpm peak may sound really low, but it is still at 410+rwhp at 6400rpm. I will shift this thing at 6200rpm or so.
I can't go crazy with timing (34^ total advance now) b/c I have a locked-out type MSD distributor (no vac. advance). So I have to be wary of having too high of timing at idle (its ~20-21^ right now).
My butt-meter maintained its reputation, though. :lol: I said the other day this car was faster than my Z06 was stock (which ran 12.3 @ 116mph) and that the car would run 11s. Well, these numbers bear that out. Should be a solid 120-122mph trap car...ET dependent upon traction, of course. :)
All in all a very nice end to a build-up that I researched ad nauseum.
Now, I'm just gonna DRIVE it! :D
A big thanks to all those who have provided help/encouragement/and info from their own experiences. I'm sure I'll miss someone, but here goes: Chuck Harmon, Jim (427Hotrod), Corey 68, Zwede, Bence, Flareside, Norval, GDaina and others. You all are great and I appreciate the help from this forum.
[Modified by WA 2 FST, 7:03 PM 7/28/2003]
Old 07-28-2003, 04:02 PM
Alwyn678
Alwyn678's Avatar
Default Re: Dyno #s for new BBC combo (WA 2 FST)
Impressive :cheers: :cool:
Old 07-28-2003, 04:03 PM
Glenn454
Glenn454's Avatar
Nice numbers!! Did you dyno with the JCL baffles In or out?
Old 07-28-2003, 04:10 PM
zwede
zwede's Avatar
Default Re: Dyno #s for new BBC combo (Glenn454)
Now those are some GREAT numbers! Congrats! Looks like AFR is maintaining their reputation of producing excellent heads.
Old 07-28-2003, 04:12 PM
WA 2 FST
WA 2 FST's Avatar
Baffles in, but uncapped. Just the way I drive it all the time. :)
Old 07-28-2003, 04:49 PM
Brettmc
Brettmc's Avatar
Not too shabby, thats ~515 hp at the crank, factoring an 18% drivetrain loss. Know it's a moot point but I wonder how much hp you could gain by bolting on a set on oval ports instead of the rectangulars. Anybody wanna chance a guess?
Brett :thumbs:
Old 07-28-2003, 04:56 PM
Bob Turner
Bob Turner's Avatar
WA 2 FST,
Wow! I am impressed! You are motivating me to get the exhaust done on my car and into the dyno shop for some tuning!!
Those cylinder heads surely are the ticket here...
I am hoping for 375 rwhp or so.....
Bob :cheers:
Old 07-28-2003, 05:07 PM
467-Ratman
467-Ratman's Avatar
Very impressive numbers on the motor , sure can't beat a BB with strong cam. The 9.5-1 compression works good too, no nead for jet fuel! My setup is very similar to yours and my car sounds very mean, especially out back. Can't wait to pay a visit to the drags in August, hoping to be in the low 13's or high 12's....
Old 07-28-2003, 05:12 PM
AGVI
AGVI's Avatar
Canadian Events Coordinator
Default Re: Dyno #s for new BBC combo (467-Ratman)
one word...WOW!!! :eek:
Old 07-28-2003, 05:35 PM
WA 2 FST
WA 2 FST's Avatar
Default Re: Dyno #s for new BBC combo (Brettmc)
Brett :thumbs:
AFR doesn't make oval ports... and if I thought a standard, non-raised exhaust oval port would make more, then I'd have bought them. :) The consensus after talking with lots of BB guys on this board was that the AFRs were the ticket. They seem to provide excellent low-end velocity, and thus are a good head even for a relatively low rpm engine (6k and under).
I know several alum. oval port cars with CR, camming, and exhaust that's pretty close to mine and they are ~400rwhp.
515hp (flywheel) isn't earth-shattering I know, but at only 5600rpm I think one would be hard-pressed to get significantly more, if any, than that. :)
Old 07-28-2003, 06:16 PM
1Bad69
1Bad69's Avatar
sweet...cam you post the printout?
Old 07-28-2003, 06:36 PM
WA 2 FST
WA 2 FST's Avatar
If your motor (and it does look similar to mine) makes the power mine does, then you will have no problem going deep into the 12s. Like I said, my '69 is faster than my Z06 (on motor) and the Z06 ran 12.3 @ 116mph on motor. I see other guys on this board with 350-370rwhp running 116mph or so (low-12s), so I know this thing with any traction at all will bust into the 11s.
You'll be there, too. :D
Old 07-28-2003, 06:38 PM
WA 2 FST
WA 2 FST's Avatar
Default Re: Dyno #s for new BBC combo (1bad69)
My scanner is broken. :( If you like I can give you the raw data and you could plot the graph yourself.
Old 07-28-2003, 06:57 PM
Flareside
Flareside's Avatar
Sounds like you got just what you wanted Wes, contrats!
Welcome to the "everyone says my cam is too small for my engine" club. I'm a lifelong member... :lol: I admire you for building it the way you want it, semi-regardless of what the dyno shows (although 430 RWHP is still a bunch!)
Since this is a strong street car, do you plan to go with a vacuum advance? Maybe you don't do much highway cruising and don't need it?
Old 07-28-2003, 07:12 PM
WA 2 FST
WA 2 FST's Avatar
Default Re: Dyno #s for new BBC combo (Flareside)
Joe,
Thanks. I still have plenty of your e-mails printed out on paper for future reference. I sincerely appreciate your help over the last 6 months or so in answering my questions.
Yes, I basically got what I wanted. I said all along, before I bought one engine part, that I would be happy at 420rwhp. So I made that and change. As far as the cam goes... I figured it would make peak HP closer to 6k, but 56-5700 is fine, too. :) Especially given the fact that the thing pulls to 6400 with ease and still makes solid power. I guess a few more degrees of duration would have been ok. Would have bumped peak HP to 6k (which following the graph would probably have put it at 445rwhp).
I have to admit I left 10-15rwhp on the dyno today. It's jetted a bit rich (~12.0:1 A/F ratio), but its also 100^F outside, and when it gets cool again I'll be glad I kept it where its at. And it will make more power to boot.
As far as the vac. advance goes, I'm a bit lost as to why it might help me on the highway? Gas mileage/fuel efficiency? I do know that all my EFI cars I've tinkered with will show 35-40+^ advance at part-throttle...and is a good reason they get good gas mileage, I know.
I don't do lots of highway driving, but definitely some. just no really long highway trips... maybe 30 miles at a time. This MSD dist. is nearly new, so I'm not sure I want to buy another just to give me vac. advance.
Old 07-28-2003, 07:26 PM
Bob Turner
Bob Turner's Avatar
Sounds familiar!!!!
:lol: :lol: :lol:
Old 07-28-2003, 07:30 PM
Jay M
Jay M's Avatar
That sounds like a fun car!! Does it all fit under the stock BB hood?
What Air cleaner are you using?
Thanks,
~Jay
To Dyno #s for new BBC combo
Old 07-28-2003, 07:36 PM
WA 2 FST
WA 2 FST's Avatar
Default Re: Dyno #s for new BBC combo (Jay M)
Thanks,
~Jay
Hi Jay,
No, I had to get an L88 hood. I'm running a 3" K&N aircleaner with an Extreme lid.
Here's a pic with the new hood.
Old 07-28-2003, 07:38 PM
Les
Les's Avatar
Stout numbers- congrats! :cheers: That's a nice recipe for others to work from. :thumbs:
Old 07-28-2003, 08:25 PM
PRNDL
PRNDL's Avatar
Default Re: Dyno #s for new BBC combo (Les)
congrats!!! but just to show you what this forum has done to me.... I'm looking at that absolutely gorgeous red vert..... sidepipes, wheels, a work of art :) and now we know what kind of power you have.... and I'm thinking, OH NO!!! He doesn't have a rollbar and I know that thing can go under 12 seconds!! :lol: MJ I hope you have a hardtop!!! :)
[Modified by MNJack, 8:26 PM 7/28/2003]
Quick Reply: Dyno #s for new BBC combo
