Part dropped out wheli working on car anyone know what this is ?
Old 07-27-2003, 08:27 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Part dropped out wheli working on car anyone know what this is ?
This part dropped out when I was hammering on the tie rod end to separate it, anyone know what it is amd where it goes ?
I am trying to have no parts left over when I finish this job for a change :lol:
[Modified by MotorHead, 7:33 PM 7/27/2003]
Old 07-27-2003, 08:35 PM
mfendley
mfendley's Avatar
Default Re: Part dropped out wheli working on car anyone know what this is ? (MotorHead)
It's a shim used when aligning the car. Look at how the control arms bolt up, and you'll probably see more of them.
norvalwilhelm
norvalwilhelm's Avatar
It's a shim for setting caster and camber. It is from between the frame and cross shaft on the A arm. Just check the spacing between the A arm and the frame to see if it fell out of the front or back. If there is another one it will be loose. Reinstall that shim and tighten the nut.
Old 07-27-2003, 08:42 PM
boredsoIstrokedit
boredsoIstrokedit's Avatar
Default Re: Part dropped out wheli working on car anyone know what this is ? (norvalwilhelm)
:yesnod:
Old 07-27-2003, 08:51 PM
arrio76
arrio76's Avatar
yes, its an alignment shim. likely it has been sitting around, laying up in some crevis where the last alignment shop mechanic dropped it and couldn't find it. All that hammering on the suspension probobly knocked out of its hiding place. But check to be sure though. Wouldn't want your front end end falling off the car. :lol:
[Modified by arrio76, 7:53 PM 7/27/2003]
Old 07-27-2003, 09:14 PM
vincevette
vincevette's Avatar
:iagree:
Old 07-27-2003, 09:27 PM
MotorHead
MotorHead's Avatar
Default Re: Part dropped out wheli working on car anyone know what this is ? (arrio76)
You guys are the greatest, thanks :D
...and yes I did have the bushings in the a arms replaced recently, one of the few jobs I did not want to do :eek:
[Modified by MotorHead, 8:29 PM 7/27/2003]
Old 07-27-2003, 11:19 PM
munday
munday's Avatar
everytime i go into my engine bay i find something new....a bolt, a nut or a some tool. :D
Old 07-28-2003, 01:27 PM
Blankman
Blankman's Avatar
Default Re: Part dropped out wheli working on car anyone know what this is ? (munday)
I find my headers eat a lot of stuff. Whenever I drop anything, be it a tool or a bolt or whatever, it always seems to end up stuck between a couple of the header pipes. Not a big deal if the car's been sitting for awhile, not so good if you just got back from a test drive and are adjusting something!!
Old 07-28-2003, 06:12 PM
AGVI
AGVI's Avatar
Canadian Events Coordinator
Default Re: Part dropped out wheli working on car anyone know what this is ? (mfendley)
:iagree:
Old 07-28-2003, 06:27 PM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Usually the only tool I find working on my car is me !
To Part dropped out wheli working on car anyone know what this is ?
Quick Reply: Part dropped out wheli working on car anyone know what this is ?
