need input on heades& side pipes vs. ram horns and chambered exhaust
when doing the body off on my 73- i coated the ram horns with por-15 high heat-and re-used the chambered ex..system-bec. the pipes had verry little use before the body off.... the problem i am having is the coating on the ex system peels off-so before shows i have to re-coat them-because i have mirrors and 400w metal haylite fixtures around the car.. i was thinking of going to headers and side exhaust-but now i seen posts that the stock ram horns flow good- if thats the case ,,i was thinking of cermac coating(chrome) the entire chambered exhaust system-which would be less expensive than--installing the headers installing the side pipes-and glassing over the rear where the stainless tips are now-some of your imput would be appreciated--carl a
Re: need input on heades& side pipes vs. ram horns and chambered exhaust (carl a)
Yes, they are good for manifolds. For perf., none of the above. See what many refer to as my Exhaust topic. http://www.corvettefaq.com/c3/ganeyexhaust.htm
You could state cam.
Re: need input on heades& side pipes vs. ram horns and chambered exhaust (Ganey)
o.k. ganey , i read your thread on exhaust-- so you think i should keep the ram horns and then send out the chamberes pipes to get creamic coated(to cure the constant painting)- as apposed to the headers and side pipes and glassin the rear where the tips are- this would be a lot cheaper and would look good in the mirrors at the shows- http://www.geocities.com/carlclub2/
[Modified by carl a, 12:01 PM 7/27/2003]
