1978 evaporative canister hose routing
What is the hose routings from the evaporative canister? The diagram shows it hooked into the PCV valve, is this correct? Thanks in advance for the info, the previous owner just pulled the hoses off and it stinks like gas!
St. Jude Donor '08
Re: 1978 evaporative canister hose routing (yogi78)
Mine Y's into the pcv from the canister and goes on the other side of the motor with the other part of the Y. I didn't have time to look where the line ended up but I will this evening if you need more info or pictures.
