What is the correct finish for steerng box/column and clutch arm, etc?
What is the correct finish for steerng box/column and clutch arm(piece that attatches to block, and master cylinder, etc? Should it be cast? Or painted? For a '68 vette.
Re: What is the correct finish for steerng box/column and clutch arm, etc? (james75)
steerin box and master cyl, are cast, z bar was zink plated, steering column semi gloss black
Re: What is the correct finish for steerng box/column and clutch arm, etc? (GDaina)
If you are trying to be NCRS correct, the steering column jacket (the outer stamped steel shell) was painted semi gloss black before it was assembled into a steering column. It also had the lower plate that attaches to the floor pan welded in place when it was painted.
The parts on the lower end: the steering shaft that sticks out of the column was bare steel; the bearing retainer was zinc plated silver; the bearing retainer clip was also zinc plated.
Hope this helps,
Jim Shea
Hope this helps,
Jim Shea
