AC Compressor Putting Alot Of Drag On Engine
At the redlights I have give to it gas or it will die. The idle goes way down to almost shutting down. Is this normal?
[Modified by OHSIXX, 1:35 PM 7/24/2003]
[Modified by OHSIXX, 1:36 PM 7/24/2003]
Re: AC Compressor Putting Alot Of Drag On Engine (OHSIXX)
I used to have a '79 Z-28 that did this after I rebuilt engine and hotrodded it a bit. Part of my rebuild was to replace the Q-jet carb with a Holley. That is when my trouble started. As I recall, on the Q-jet there is an electric component that would make up for the A/C drag by upping the idle when the A/C was running. I am sure this available for the Holley as well but I was not smart enough to get it all back together back then. I am sure someone else here can give you the gory details, but that sounds like your problem to me.
CVT4ME
CVT4ME
Re: AC Compressor Putting Alot Of Drag On Engine (CVT4ME)
CVT4ME
CVT4ME
Brett :thumbs:
Re: AC Compressor Putting Alot Of Drag On Engine (Brettmc)
:iagree: Yup, need a solenoid to up the idle when the a/c comes on. Or, you could increase the idle but it will be high when the a/c is not on.
Brett :thumbs:
Brett :thumbs:
Re: AC Compressor Putting Alot Of Drag On Engine (dath)
Thanks! This is a terrific place. :)
