CTSY Fuse keeps blowing
Cruising
Hello! I have the vette fever. Purchased my 1981 Dark Blue coup about a week ago. I have a problem that I need some help on. When I got the car the passenger right window would not work. The dome light, glove box light, lighter, horn and power door locks did not work. Removed door panel and checked for power to the window motor..it had power, so I assumed it was the motor. Put everything back together and the window worked..humm! Replaced the CTSY fuse and it lasted about 3 seconds, long enough to verify the locks do work ..here is where I am at:
Disconnected Glove box light, lighter, both power door switches and taped door pillar shut. Installed new fuse..blew immediately. Horn does not work, so will check it next. Do I gave a ground problem? Could it be a "live" wire that is rubbing. Are there any trouble shooting instructions in the shop manual (hopefully will receive mine in the next few days) that someone could send me....
:banghead:
:banghead:
Re: CTSY Fuse keeps blowing (Feltman)
:seeya Welcome to the forum.
Check the hot wire comming off the bottom of the cigarette lighter housing. They sometimes fall off and touch somthing on the frame causing the fuse to blow. Otherwise its prolly gonna be a similar problem with a different wire. Oh, also check to make sure nothing, like a penny, fell down into the cig. lighter socket. That would cause the fuse to blow also (ask me how I know ;) )
:cheers:
:cheers:
Cruising
Re: CTSY Fuse keeps blowing (77Dream)
Your welcome:cheers:
Thanks---I did disconnect both wires from the lighter..still blew....I will not ask about the object in the lighter..already know the answer :auto:
There are many lights behind the instument panel, speedo, and tach that can come loose and short out. This is not a fun item to track down. I also consider dash work to be about the worst.
Chuck
Chuck
If so I would suspect your short is somewhere in that system between the switch and one of the lock solenoids in the doors.
:banghead:
:banghead:
Here is a link to a place that sells it, but you may find it elsewhere for less - I just wanted to give you an idea.
http://www.salejr.com/automotive/14ZX9374U.html
EVERYONE should have one in the back of their toolbox! If you use it once, you'll be glad you bought it forever!
Cruising
Re: CTSY Fuse keeps blowing (pws69)
Awesome--I will have one by this weekend. This is why I joined this forum to get help when needed..hopefully I can repay the favor :seeya
