Victor Jr. or Performer RPM?
my engine specs are in my sig, and I have access to used versions of each of these intakes, which should I go with? will I have clearance issues with either? (Q-Jet carb)
Re: Victor Jr. or Performer RPM? (Glutamine83)
can you put a q-jet on a victor jr?
I don't believe Edel ever made a Q-Jet Victor Jr.
The Perf RPM can be had in either configuration.
Since this would be used, I'd make sure the Perf RPM is for a Q-jet. You really don't want to run an adaptor.
Re: Victor Jr. or Performer RPM? (QuickVet)
The Vic Jr is square bore only,and for a street driver I'd stick with a dual plane.I have the RPM Q-Jet and it fits under the stock hood with a drop base filter easily.
[Modified by The Money Pit, 9:01 PM 7/24/2003]
Re: Victor Jr. or Performer RPM? (The Money Pit)
TO: The Money Pit,
I just brought a performer RPM Q-jet manifold (#7104) and I going to run a rochester Q-jet on it. What drop base air cleaner do you use and will it work with my carb? I have the stock small block hood and need to make everything fit.
Also i plan on switching to a holley or demon carb sooner or later and want to know if a square bore will bolt onto the Q-Jet RPM manifold. The manifold looks like it has the holes for both a square bore and a spread bore but I'm not possitive.
Thanks
Thanks
Re: Victor Jr. or Performer RPM? (L-82kid)
It's a GM Performance 14" filter with a 3" element.The Holley will fit the RPM-Q Jet intake for sure.I switched mine from an Edelbrock 1904 (Q-Jet clone) to a Holley 3310.
I'd try to find an original Torker manifold. They are sold on ebay all the time and all the ones I've seen work with the Q-Jet.
If you want to buy new, check out the Team G street ram: http://www.holley.com/HiOctn/ProdLin...AMSM/7525.html
Re: Victor Jr. or Performer RPM? (BeaterShark)
I'd say it depends on what transmission you have.
3 speed automatics require a wider powerband because of the greater rpm drop between shifts as opposed to a 4,5, or 6 speed stick. If your car is an automatic, the the RPM is a better choice because of the longer runners on the manifold which will help intake velocity and torque.
The Victor Jr is a better match to a stick because it gives up some lowend torque, but the engine spends more time in the higher rpm range so shorter runners are a better choice in this application.
IMHO, I have to agree with BeaterShark on the 298/304 cam being a bit much on the street. Also if your building a high preformance engine, I don't know much about Q-Jets, but Holleys are a good choice and fit many more common intakes too ;) .
