Electric vacuum pump ?
Somewhere I remember reading about an electric vacuum pump for use on engines with low engine vacuum due to cam changes. Has anyone used one of these or know who sells them ? I thought it would be a great idea on the '76 as there are so many vacuum lines. TIA
Re: Electric vacuum pump ? (rayosequis)
They are advertised everywhere, before you install one make sure you have no leaks in your vacum hoses, your vette should easily produce 14 to 18 of vacume with most of the street cams.
