I need a 12v line for my electric choke...where can I look?
My RPMs are through the roof without the electric choke for the street avenger connected. My Q-jet didn't have an electric choke so there is no readily available line for me to hook up to. Where can I find a 12v line that's hot only when the car is running? Thanks everyone!
Re: I need a 12v line for my electric choke...where can I look? (Phoenix79)
There are usually "extra" terminals on the wiring harness outlet near the fuse box. Just put your voltmeter(multimeter) on a terminal that appears to be "free". If it has voltage on it only when you turn the key, then you can use it.
I used a loaner carb from Lars that had an electric choke. He told me to pick up the power at the wiper motor. Worked like a charm. Just make sure you get a power lead that is switched.
For a temp hookup I just pushed a spade terminal into the connection. I am sure you will want a more permanent connection.
Here is a address for a great article(s) on carburetors (mostly Q-jets) but it does have the best write up on electric choke wiring that I've seen. Good reading about carbs too. http://www.442.com/oldsfaq/ofcrb.htm . Good luck Phoenix. :thumbs:
Re: I need a 12v line for my electric choke...where can I look? (Indy Year 25)
I like the idea of using power from the Wiper motor. My wiper motor has 3 wire connectors. There are two connections on the driver's side of the motor with multiple wires and one connector, a red wire wire on the passenger side of the wiper motor. I'm sure its safe to assume the wiper motor is the stock one for a 79. Which connection or wire has power with the car running?
I really need to go a voltmeter...
