Starter Bendix question... 153 vs 168
St. Jude Contributor
What's the difference between the bendix tooth count(or tooth formation) on starters that are designed for 153 & 168 tooth flexplates(flywheels)?
Yep!! I'm still starter stuck. :(
Re: Starter Bendix question... 153 vs 168 (bgrice)
Not a thing. The only difference between the two starters is the nose cone of the starter. And yes you can swap out the starter nose cones from a 153 to a 168. Some starters have larger motors and higher torque ratings.
