Started out as a cam swap here the "While I'm at it" list
Old 07-22-2003, 01:39 AM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Started out as a cam swap here the "While I'm at it" list
Started out as a simple cam swap, my 270H to 282S, here the "While I'm at it" list.
1) Cam and lifters
2) Harland Sharp aluminum roller rockers( couple more HP while I'm in there ?)
3) Victor Junior intake( can't have a high revving cam without the intake )
4) Moroso 7qt side kickout oil pan ( why not ?)
5) Carter high flow mechanical fuel pump (couldn't hurt )
6) Cloyes double roller timing set ( must have )
7) Stewart Stage II aluminum water pump ( heck I got the old one off now)
8) Earl's fuel filter
9) March underdrive pulley set ( hey they're shiny)
10) Cloyes 2 piece aluminum timing chain cover
And I only have the rad out right now,so I'm sure there is going to be more. :D
[Modified by MotorHead, 7:39 AM 7/22/2003]
Old 07-22-2003, 02:05 AM
gdh
gdh's Avatar
Default Re: Started out as a cam swap here the "While I'm at it" list (MotorHead)
what ever happened to that NOS kit you bought last year?
Old 07-22-2003, 02:09 AM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Where's the supercharger? :confused: :D
Old 07-22-2003, 02:36 AM
Chris O'
Chris O''s Avatar
I'm still paying off the last bout of "while I'm at it's". :lol:
Old 07-22-2003, 04:47 AM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
You're right, you may as well change all that now than decide a month from now to change the pan, then the pump. It's better all at once that piece meal. :yesnod:
What no aluminum timing cover? :confused: :lol:
Old 07-22-2003, 05:56 AM
Fevre
Fevre's Avatar
With that 10% discount from Summit I might have to go overboard too. :yesnod:
Old 07-22-2003, 06:52 AM
foundvettelifeisgood
foundvettelifeisgood's Avatar
Exactly which pulley set did you get? Thanks.
Old 07-22-2003, 07:01 AM
Jvette73
Jvette73's Avatar
The roller rockers might require guide plates and hardened pushrods. If yur heads still have pressed in rocker studs, the will have to come off and go to the machine shop to be drilled and tapped for screw in studs to accept guide plates. What heads do you have now? If they come off I can think of a few more "while yur at it's". Hmm some porting and polishing maybe? I ported and polished mine myself. Its time consuming but not difficult or expensive if you do it yourself. Whats the casting # on yur current heads?
oops ..just saw yur sig and I see you have the sportsman II heads....duh
[Modified by Jvette73, 6:02 AM 7/22/2003]
Old 07-22-2003, 07:56 AM
SuperFast80
SuperFast80's Avatar
10) Painting it beige.... :lol:
Old 07-22-2003, 08:10 AM
mountainmotor
mountainmotor's Avatar
Looks like valve springs was forgotten :chevy
Old 07-22-2003, 08:48 AM
MotorHead
MotorHead's Avatar
Default Re: Started out as a cam swap here the "While I'm at it" list (1970 Stingray)
1970 Stingray - Thanks for reminding me I knew I forgot something, I have a Cloyes aluminum timing chain cover for it
I have Sportsman II heads that already have the recommended springs installed with guide plates and hardened pushrods, but thanks for the heads up.
I do plan on getting them ported but not untill the go on the 400 stroker.
foundvettelifeisgood - March pulley set is #5070 specifically made for Corvettes..
gdh - Lost interest in the nitrous install and sold it besides I want to make HP the old fashioned way :lol:
Old 07-22-2003, 08:56 AM
isosceles
isosceles's Avatar
Drat! I was planning a cam swap myself and thought MAYBE of getting the radiatior rodded "while I was at it". I already have the Stewart Stage II, but since I'll HAVE to do the rest of that stuff, I'll have to wait until the mortgage is paid off to afford it! :jester
To Started out as a cam swap here the "While I'm at it" list
Quick Reply: Started out as a cam swap here the "While I'm at it" list
