Losing my cool (and my heat) on wifes 79
I'm into the area behind the dash. Yeah I got it out, broke the pass. corner but did get it out. I found a bunch of vacuum lines disconnected and some pluged. At the air/heat control with a hand vacuum pump I can: open the fresh air door and it holds vacuum, I can open the center door and hold the vacuum (I think it is the defrost), I can open and hold the vacuum on the door that swings in on the right of center. I have white and black lines that are disconnected and no apparent routing. I think they go to the under hood area one to the heat control valve the other is a mystery. Anyone have any ideas where these lines go and to what? Are there any drawings posted any where on the web? Thanks in advance I know the C3 brotherhood won't let me down. :thumbs:
Re: Losing my cool (and my heat) on wifes 79 (87bob)
Here is the vacuum diagram. http://home.comcast.net/~chadwick.ro...ate-vacuum.pdf
Re: Losing my cool (Bobchad)
thanks, i printed a copy of that, as i have no defrost in my 79. this will be handy to have.
[Modified by Gary79, 5:34 AM 7/22/2003]
