Intake /carb
1st Gear
Intake /carb
I have a low mileage 74 coupe with the original 454 and I will be trying to upgrade the breathing capability of the engine and still keep the original hood.
Any opinions on what Intake/Carb. setup I can use.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Intake /carb (mm74ray)
well, I came in here to give some suggestions, but I don't have the big block.
So, instead I will just say
Welcome to the Corvette Forum !
A BB owner will have to get this one for ya.
Just corious..do the 74 big blocks come with cowl induction such as on the small blocks in that year? Do you have a q-jet carb on there now? How about sending it to lars for a prep. The CFM rating of the q-jet should be enough to make a nice performance piece provided its set up right. if the 74 has a cowl induction hood factory. I would stick with a stock height aluminum intake to keep that all functional. Definatly loose some big time weight with an aluminum manifold. Gain some better flow characteristics at the same time.
:cheers:
Pat Kunz
