Body mount questions
I'm attempting to replace the #3 mounts because they are pretty much gone. The left side is gone and the right has a broken bolt. I found the left unsupported so I used a socket to hold the body up,same for the right.
What is the correct way to set the mount/body height? There were no shims on the old mounts. The right was diffinately supported by the old mount but the left must have dropped a while ago?
Any tricks to get the bolt out? I'll try to weld a bolt on to it but it might be rust welded. I soaked it with PB blaster overnight.
Thanks,
Gary
Thanks,
Gary
