How-To Question: Replacing motor mounts without removing the motor?
Location: At the end of 2 big long black marks on #2 Sideroad and Walkers Line.
I realized on friday night (just before the poker run :mad) that I had a broken motor mount (Drivers side, Metal was broken). So I need to replace them. I have found them at various diffrent suppliers, but I don't really know how I would go about changing them out.
Any help would be great.
Thanks in advance.
chris.
Thanks in advance.
chris.
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: How-To Question: Replacing motor mounts without removing the motor? (PyjamaSam)
It's not real hard, but it can be a little tricky. Put a board under your oil pan and jack the engine up enough to remove the broken mount. Then (this is the tricky part) use a little Corvette yoga to get the new mount into position to bolt down. BTW, you don't need to jack the engine up much to get it in position for the swap.
Re: How-To Question: Replacing motor mounts without removing the motor? (Smokehouse69)
a lot of yoga you mean, its a pain in the butt to do that. but its possible
Re: How-To Question: Replacing motor mounts without removing the motor? (gravismaximus)
I just replaced both of mine last month and it is a bit of a pain. you will need a long 3/8s extension and a swivel socket to loosen the bolts. Also check that the new mounts have an oblong hole for the long bolt to go through. The ones that I got only had a round hole and there was no way I could get the bolt in, so I had to remove the mounts and use a die grinder to oblong the holes. Also if you have the lower chrome shielding around your plug wires they can be a PITA as they mount to one of the motor mount bolts. The higher you can get your car off of the ground the better. Good Luck, Craig
The oil pan can support that kinda weight. Hmm. Ok.
Any accessories that might be usefull to remove to make the job go a bit smoother.
chris.
chris.
