82 check engine light
How do you reset the check engine light in a 82 C/E. We replaced the A.I.R. pump and when we check the trouble codes all the ashows in a code 12 (normal , no problems?). How do you get the light to go out?
Re: 82 check engine light (toyvet1)
Is the ;ight on with the engine running?? You can reset the ecm by unhooking the battery for 30 seconds
If the CEL relights after you start it back up, something's wrong
Marck
Marck
Re: 82 check engine light (Twin_Turbo)
:iagree: dis-connect the battery to reset and erase the trouble codes. Just make sure the ignition is not turned on when you dis-connect. If it is in the on position when you unhook the bat it will give the putor a labotomy.
