Mallory Dual Point Distributor
Old 07-19-2003, 09:15 PM
lvrpool32
lvrpool32's Avatar
Default Mallory Dual Point Distributor
I recently bought a used tach drive, dual point distributor, I say used but there isn't a mark on it. On closer inspection today I noticed that one of the sets of points isnt connected to anthing. Both sets of points have a brown wire that connects to the ballast resistor then to the coil.
Shoulw both wires be connected? i would think they both would, any help would be appreciated.
cheers
Nick
Old 07-19-2003, 10:33 PM
yellow 72
yellow 72's Avatar
St. Jude Donor '09
Default Re: Mallory Dual Point Distributor (lvrpool32)
More than likely someone unhooked one of the sets of points to make setting the dwell easier. Both sets of points should be connected by a jumper wire and naturally the - side of the coil. I take it you mean the brown wire is attached to a condenser which is correct.....
Mike :cheers:
Quick Reply: Mallory Dual Point Distributor
