New fuel filter for 6AN line, which one ?
Going to finish off the braided hose down to the fuel pump. What fuel filters are you guys using for the braided line ? Pics wpuld be nice too :D
Cruise-In IX Veteran
Re: New fuel filter for 6AN line, which one ? (MotorHead)
I am getting ready to do a -AN setup for my car. I am going to go with an Earls filter. I hear they work pretty well.
I use a normal ~2" dia 3" long 3/8 piped stainless filter in the SUCTION side of my fuel pump, which then pushes forward to the DPFI setup....
nothing under the hood....
GENE
GENE
Re: New fuel filter for 6AN line, which one ? (Twin_Turbo)
Hmmm kinda like that Earl one, that's not glass is it ?
Re: New fuel filter for 6AN line, which one ? (dman535)
iyou do not want one of those glass/perspex see throigh things. The only thing they're good for is in a PCV line back to the carb, you can replace it when it's all dirty. keeps the intake nice & clean.
I have one here:
I have one here:
I use the Fram remote also but that damn copper washer at the top leaks EVERYTIME I change the element (I now have two washers under the bolt). If I had to do it over (and I might) I would go with an inline that had AN males on the ends. ...redvetracr
Re: New fuel filter for 6AN line, which one ? (redvetracr)
I just use the Summit Racing brand fuel filter part # G1516-8 8-AN The BG140006 for Demon carbs fuel log Earls 8-AN to 3/8 90 degree hose adapter. Maybe a 18 inch length of steel braided hose which I ran over the top of the exsisting steel line from the stock type bypass mech fuel pump.
It makes for a bullet proof non leaking system
TT mines blue, but it's the same.
This is my motor on a test stand and picture number two was when I still had a mech. fan last year
