Leaking fuel sender
Leaking fuel sender
Last night while out cruising, me and my buddies noticed fuel dripping from the tank. A closer inspection reveals gas dripping from the sender. It looks like the gasket, I'm assuming there is a gasket, is leaking. This is a new tank installed by the previous owner. From looking at the sender, it looks like I have to turn it to remove it. Is anyone familiar with this procedure? I looked through the archives, and found sending units that were bolted on, but I don't see bolts. I double checked before posting, and it looks like there are tabs keeping the sender from turning, but there are NO bolts holding the unit in. I need your help on this one. I obviously can't drive the car with a leak like this!
Thanks.
Ken
Thanks.
Ken
Re: Leaking fuel sender (bb69)
its a locking ring that you turn to take out the sending unit and theres a oring that seals it,usually they dry out and split and leak.Just tap the ring around till it meets up with the 3 spaces and itll come out,then you can remove the sending unit out .
[Modified by patsnitrovette, 10:33 AM 7/19/2003]
Re: Leaking fuel sender (patsnitrovette)
Thanks for the reply. I just got done siphoning (sp) out the gas and came in to check for replies. I'm headed back out now with my new found info.
Updates to come....
Updates to come....
