Hood Insulation...how do you install it on a 75?
Old 07-18-2003, 11:54 PM
vetteguy75
Support Corvetteforum!
vetteguy75's Avatar
LA Events Coordinator
Default Hood Insulation...how do you install it on a 75?
I am removing the old insulation (glued to the hood) and replacing it correctly with the GM insulation, clips and retainers. Question: how do you attach the clips to the hood? Expoxy Glue? and if so....where do I place the clips on the hood to line up with the insulations holes? :crazy:
Old 07-19-2003, 07:40 AM
Big Fish
Big Fish's Avatar
A CI-6 Car Show Winner
Default Re: Hood Insulation...how do you install it on a 75? (vetteguy75)
If you look carefully at the underside of the hood there are circles molded in that indicate where the mounts belong. I thing there are 11 of them, the one on the air duct is not marked, you will need to measure for it. Someone told me to use J/B weld, but I haven't got that far yet so I can't say from experience it would work. Make sure the attachment spots are clean, free of paint, and scuff those areas as well as the mount studs prior to adhesion. I would try just one with the J/B weld and then see if it held well before doing the rest.
Old 07-19-2003, 09:01 AM
vetteguy75
vetteguy75's Avatar
THANKS!!! I'll give it the 'ol college try! :hurray:
To Hood Insulation...how do you install it on a 75?
Quick Reply: Hood Insulation...how do you install it on a 75?
