question for chambered exhaust owners
Did you use the stock muffler hangers in the rear or did you have to "wing it".
I have the pipes but no hangers. Not sure how many to use either, all responses, as usual, will be appreciated.
thanks
thanks
Re: question for chambered exhaust owners (dlw)
This wont help much but... I bought my chambered system used so the previous owner had hangers welded to the pipes. It does however bolt up to the stock mounting points. So I say yes, use the stock hangers and clamp them to the pipes.
Re: question for chambered exhaust owners (Stewart's74)
:withstupid:
I think the installer welded a strip to the tail end of the chambered tail pipe, which mates to the stock rear mounts with a bolt, nut and washer.
Senior Member since 1492
I used the only the rear hangers MAD supplied. If there's supposed to be another hanger around the diff, I wasn't aware of it. :confused: The pipes are pretty close to the diff as is.
